How to upgrade MAAS
PostgreSQL 12 is deprecated with the release of MAAS 3.3, in favour of PostgreSQL 14. Support for PostgreSQL 12 will be discontinued in MAAS 3.4.
How to upgrade a snap to MAAS 3.3
To upgrade from a earlier snap version to the 3.3 snap (using a region+rack configuration):
  1. Enter the following command:
sudo snap refresh --channel=3.3 maas
  1. Enter your account password.
The snap will refresh from the 3.3 channel. You will not need to re-initialise MAAS.
How to upgrade MAAS 2.9++ to MAAS 3.3
If you are running MAAS 3.2 through MAAS 2.9, you can upgrade directly to MAAS 3.3 with the following procedure:
  1. Check whether the target system is running Ubuntu 22.04 LTS:
lsb_release -a
Distributor ID:	Ubuntu
Description:	Ubuntu xx.yy
Release:	xx.yy
Codename:	$RELEASE_NAME
The required “xx.yy” for MAAS 3.3 is “22.04,” code-named “Jammy”.
  1. If you are currently running Ubuntu focal 20.04 LTS, Upgrade to Jammy 22.04 LTS:
  1. Accept the defaults for any questions asked by the upgrade script.
  2. Reboot the machine when requested.
  3. Check whether the upgrade was successful:
lsb_release -a
Description:	Ubuntu 22.04(.nn) LTS
Release:	22.04
Codename:	jammy
How to upgrade MAAS 2.8-- to MAAS 3.3
If you’re upgrading from MAAS version 2.8 or lower to version 3.3, try the fooling procedure. While the this procedure should work, note that they it’s untested. Use at your own risk.
  1. Back up your MAAS server completely with your favorite tools and media.
  2. Add the MAAS 3.3 PPA to your repository list; ignore any apparent error messages:
sudo apt-add-repository ppa:maas/3.3
  1. Upgrade the release; answer any questions with the default values:
  1. Check whether your upgrade has been successful:
lsb_release -a
No LSB modules are available.
Release:	22.04
Codename:	jammy
  1. Check your running MAAS install (by looking at the information on the bottom of the machine list) to make sure you’re running the 3.3 release.
If this didn’t work, you will need to restore from the backup you made in step 1, and consider obtaining separate hardware to install MAAS 3.3.
How to upgrade a snap to MAAS 3.2
To upgrade from a earlier snap version to the 3.2 snap (using a region+rack configuration):
sudo snap refresh --channel=3.2 maas
The snap will refresh from the 3.2 channel; you will not need to re-initialise MAAS.
How to ugprade MAAS 2.9++ to MAAS 3.2
To upgrade from MAAS 2.9 - 3.1 to MAAS 3.2, follow these steps:
  1. Back up your MAAS server completely; the tools and media are left entirely to your discretion.
  2. Add the MAAS 3.2 PPA to your repository list with the following command, ignoring any apparent error messages:
sudo apt-add-repository ppa:maas/3.2
  1. Run the MAAS upgrade:
sudo apt update
sudo apt upgrade maas
  1. Check your running MAAS install (by looking at the information on the bottom of the machine list) to make sure you’re running the 3.2 release.
  2. If this didn’t work, you will need to restore from the backup you made in step 1, and consider obtaining separate hardware to install MAAS 3.2.
How to upgrade MAAS 2.8-- to MAAS 3.2
If you are running MAAS 2.8 or lower, you can’t upgrade directly to MAAS 3.2:
  1. Make sure that the target system is running Ubuntu 20.04 LTS or higher:
lsb_release -a
Release:	xx.yy
The minimum “xx.yy” required for MAAS 3.2 is “20.04,” code-named “focal.”
  1. If you’re not running focal, pgrade the release:
lsb_release -a
Description:	Ubuntu 20.04(.nn) LTS
Release:	20.04
Codename:	focal
How to upgrade a snap to MAAS 3.1
To upgrade from a earlier snap version to the 3.1 snap (using a region+rack configuration):
  1. Refresh the snap:
sudo snap refresh --channel=3.1 maas
The snap will refresh from the 3.1 channel. You will not need to re-initialise MAAS.
How to ugprade MAAS 2.9++ to MAAS 3.1
You can upgrade from MAAS 2.9 or MAAS 3.0 to MAAS 3.1:
  1. Back up your MAAS server completely; the tools and media are left entirely to your discretion. Just be sure that you can definitely restore your previous configuration, should this procedure fail to work correctly.
  2. Add the MAAS 3.1 PPA to your repository list with the following command, ignoring any apparent error messages:
sudo apt-add-repository ppa:maas/3.1
  1. Run the MAAS upgrade like this:
sudo apt update
  1. Check your running MAAS install (by looking at the information on the bottom of the machine list) to make sure you’re running the 3.1 release.
  2. If this didn’t work, you will need to restore from the backup you made in step 1, and consider obtaining separate hardware to install MAAS 3.1.
How to upgrade MAAS 2.8-- to MAAS 3.1
If you are running MAAS 2.8 or lower, you can also upgrade directly to MAAS 3.1, but it requires some extra steps. You must first make sure that the target system is running Ubuntu 20.04 LTS or higher, by executing the following command:
lsb_release -a
Release:	xx.yy
The minimum “xx.yy” required for MAAS 3.0 is “20.04,” code-named “focal.”
If you are currently running Ubuntu bionic 18.04 LTS, you can upgrade to focal 20.04 LTS with the following procedure:
  1. Upgrade the release:
lsb_release -a
Release:	20.04
Codename:	focal
How to upgrade a snap to MAAS 3.0
To upgrade from a earlier snap version to the 3.0 snap (using a region+rack configuration), do the following:
sudo snap refresh --channel=3.0 maas
  1. Enter your user password.
The snap will refresh from the 3.0 channel. You will not need to re-initialise MAAS.
How to ugprade MAAS 2.9 to MAAS 3.0
To upgrade a working MAAS 2.9 instance to MAAS 3.0, follow these steps:
  2. Add the MAAS 3.0 PPA to your repository list:
sudo apt-add-repository ppa:maas/3.0
sudo apt update
  1. Check your running MAAS install (by looking at the information on the bottom of the machine list) to make sure you’re running the 3.0 release.
  2. If this didn’t work, you will need to restore from the backup you made in step 1, and consider obtaining separate hardware to install MAAS 3.0.
How to upgrade MAAS 2.8-- to MAAS 3.0
If you are running MAAS 2.8, you can upgrade directly to MAAS 3.0 with the following procedure:
  1. Check your release:
lsb_release -a
Release:	xx.yy
lsb_release -a
Release:	20.04
Codename:	focal
How to upgrade a snap to MAAS 2.9
To upgrade from an earlier snap version to the 2.9 snap (using a region+rack configuration), do the following:
sudo snap refresh --channel=3.0/stable maas
How to upgrade MAAS 2.8-- to MAAS 2.9
MAAS 2.8 is the last supported version for Ubuntu 18.04 LTS. Newer versions of MAAS will not be back-portable, and consequently, to upgrade to MAAS 2.9 and all future versions, you will also need to upgrade the base operating system to Ubuntu 20.04.
You do these two operations all at once, with the following procedure:
  1. Add the 2.9 PPA to your repository path list:
sudo add-apt-repository ppa:maas/2.9
  1. Run the release upgrade:
  1. Reboot your machine (requested by the upgrade script).
  2. Check that your upgrade was successful:
lsb_release -a
Description:	Ubuntu 20.04.1 LTS
Release:	20.04
Codename:	focal
You have now upgraded to the Ubuntu 20.04 LTS base, and if you check your running MAAS install, you should see that the version has been updated to the latest stable 2.9 release.
Last updated 3 months ago.
