To keep your MAAS setup transparent, we’ve engineered it for observability — you can gauge its internal state purely through telemetry data. Depending on your MAAS version, your monitoring toolkit will differ.
Make sure to navigate to the section that matches your MAAS version.
Monitoring with MAAS 3.5+
From version 3.2 onward, MAAS simplifies the integration process with key Grafana stack components like Prometheus and Loki. Use this data seamlessly with an open-source stack, whether it’s orchestrated by Juju—like the Canonical Observability Stack—or a third-party solution, be it SaaS or self-managed.
Below is a reference observability stack featuring Prometheus for metric collection and alerting, Loki for log aggregation and alerts, Grafana for visualization, Alertmanager for handling notifications, and Grafana Agent as the telemetry collector.
This section walks you through setting up the stack to ingest telemetry data and trigger alerts for failures.
O11y requirements
- an Ubuntu host with MAAS 3.5+ running
- an Ubuntu host with enough storage capacity to hold logs and metrics’ time-series
Both hosts need internet access for installation. While we employ LXD for a single-host setup, it’s not mandatory. For production use, consult the Prometheus and Loki docs to enhance security and performance.
Configuring O11y
In monitoring MAAS, you’ll need to follow three key steps: set up your tool stack, export telemetry data, and validate that it’s all running smoothly.
Configure the stack
Create a VM with the following script to install all required software.
export LXD_NET=virbr0
export GRAFANA_REPOS=https://packages.grafana.com/oss/deb
export GRAFANA_KEY=https://packages.grafana.com/gpg.key
export LOKI_PKG=https://github.com/grafana/loki/releases/download/v3.4.2/loki-linux-amd64.zip
export PROM_PKG=https://github.com/prometheus/prometheus/releases/download/v3.2.1/prometheus-3.2.1.linux-amd64.tar.gz
export PROM_ALERT_PKG=https://github.com/prometheus/alertmanager/releases/download/v0.28.1/alertmanager-0.28.1.illumos-amd64.tar.gz
cat <<EOF | lxc launch ubuntu: o11y
config:
user.user-data: |
#cloud-config
apt:
sources:
grafana:
source: 'deb ${GRAFANA_REPOS} stable main'
key: |
$(wget -qO- ${GRAFANA_KEY} | sed 's/^/ /')
packages:
- unzip
- grafana
- make
- git
- python3-pip
runcmd:
- mkdir -p /opt/prometheus /opt/loki /opt/alertmanager
- wget -q "${LOKI_PKG}" -O /tmp/loki-linux-amd64.zip
- unzip /tmp/loki-linux-amd64.zip -d /opt/loki
- chmod a+x /opt/loki/loki-linux-amd64
- wget -qO- "${PROM_PKG}" | tar xz --strip-components=1 -C /opt/prometheus
- wget -qO- "${PROM_ALERT_PKG}" | tar xz --strip-components=1 -C /opt/alertmanager
- cat /dev/zero | sudo -u ubuntu -- ssh-keygen -q -N "
ssh_authorized_keys:
- $(cat ${HOME}/.ssh/id_rsa.pub | cut -d' ' -f1-2)
description: O11y stack
devices:
eth0:
type: nic
network: ${LXD_NET}
EOF
# log into the VM
lxc shell o11y
Next, you have to configure and start four services, include Prometheus, Loki, AlertManager, and Grafana. Once these services are started, you can proceed to export telemetry data and see how your observability tools are working.
Configure Prometheus
Create the Prometheus configuration.
cat > /opt/prometheus/prometheus.yaml <<EOF
global:
evaluation_interval: 1m
rule_files:
- /var/lib/prometheus/rules/maas/*.yml
alerting:
alertmanagers:
- static_configs:
- targets:
- localhost:9093
EOF
MAAS has a git repository of curated alert rules for Prometheus. Checkout this repository, compile the rules and copy them to prometheus directory.
git clone https://github.com/canonical/maas-prometheus-alert-rules.git
cd maas-prometheus-alert-rules
make python-deps groups
mkdir -p /var/lib/prometheus/rules/maas
cp group.yml /var/lib/prometheus/rules/maas/
Start the Prometheus service. You should enable the Remote-Write Receiver function.
systemd-run -u prometheus /opt/prometheus/prometheus \
--config.file=/opt/prometheus/prometheus.yaml \
--web.enable-remote-write-receiver
Configure Loki
Create the Loki configuration.
cat > /opt/loki/loki.yaml <<EOF
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
path_prefix: /var/lib/loki/
storage:
filesystem:
chunks_directory: /var/lib/loki/chunks
rules_directory: /var/lib/loki/rules
replication_factor: 1
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
ruler:
alertmanager_url: http://localhost:9093
evaluation_interval: 15s
poll_interval: 1m
storage:
type: local
local:
enable_api: true
EOF
MAAS has a git repository of curated alert rules for Loki. Checkout this repository, compile the rules and copy them to Loki directory.
git clone https://github.com/canonical/maas-loki-alert-rules.git
cd maas-loki-alert-rules
make groups
mkdir -p /var/lib/loki/rules/fake
cp rules/bundle.yml /var/lib/loki/rules/fake/
Start the Loki service.
systemd-run -u loki /opt/loki/loki-linux-amd64 \
--config.file=/opt/loki/loki.yaml
-validation.allow-structured-metadata=false
Start AlertManager
The default configuration is enough for receiving alerts from Prometheus and Loki. You should read the project documentation to change it to forward notifications to somewhere useful.
systemd-run -u alertmanager /opt/alertmanager/alertmanager \
--config.file=/opt/alertmanager/alertmanager.yml
You can access the AlertManager dashboard at http://<VM_IP>:9093
Start Grafana
Grafana works out-of-the-box with the default configuration.
systemctl enable grafana-server
systemctl start grafana-server
You can access the dashboard at http://<VM_IP>:3000, the default user/password is “admin”.
Export telemetry
The Grafana Agent should be installed in the same host as MAAS.
export O11y_IP=<O11y_IP>
export GRAFANA_AGENT_PKG=https://github.com/grafana/agent/releases/download/v0.44.2/grafana-agent-linux-amd64.zip
wget -q "${GRAFANA_AGENT_PKG}" -O /tmp/agent.zip
unzip /tmp/agent.zip -d /opt/agent
chmod a+x /opt/agent/grafana-agent-linux-amd64
Copy the agent example configuration from MAAS based on the installation method and start the agent:
mkdir -p /var/lib/grafana-agent/positions \
/var/lib/grafana-agent/wal
# for snap
cp /snap/maas/current/usr/share/maas/grafana_agent/agent-example-snap.yaml /opt/agent/agent.yaml
# for deb
cp /usr/share/maas/grafana_agent/agent-example-deb.yaml /opt/agent/agent.yaml
systemd-run -u telemetry \
-E HOSTNAME="$(hostname)" \
-E AGENT_WAL_DIR="/var/lib/grafana-agent/wal" \
-E AGENT_POS_DIR="/var/lib/grafana-agent/positions" \
-E PROMETHEUS_REMOTE_WRITE_URL="http://${O11y_IP}:9090/api/v1/write" \
-E LOKI_API_URL="http://${O11y_IP}:3100/loki/api/v1/push" \
-E MAAS_IS_REGION="true" \
-E MAAS_IS_RACK="true" \
-E MAAS_AZ="default" \
/opt/agent/grafana-agent-linux-amd64 \
-config.expand-env \
-config.file=/opt/agent/agent.yaml
Next, enable log forwarding in MAAS.
# set the TCP port the Grafana Agent is listening for syslog messages
# this port must match the one in /opt/agent/agent.yml
maas $ADMIN maas set-config name=promtail_port value=5238
# enable syslog forwarding
maas $ADMIN maas set-config name=promtail_enabled value=true
Verify operation
Once your stack is set up, verifying its operation becomes crucial. You should be able to add both Loki and Prometheus as data sources in Grafana. This enables you to craft dashboards that bring MAAS metrics to life. Beyond that, you’ll want to fine-tune Alertmanager to ensure that you’re receiving timely and relevant alerts.
Monitoring with MAAS 3.4-
O11y requirements
- an Ubuntu host with MAAS 3.2+ running
Configuring O11y
Configure the stack
export LOKI_PKG=https://github.com/grafana/loki/releases/download/v2.4.2/loki-linux-amd64.zip
export PROM_PKG=https://github.com/prometheus/prometheus/releases/download/v2.31.1/prometheus-2.31.1.linux-amd64.tar.gz
export PROM_ALERT_PKG=https://github.com/prometheus/alertmanager/releases/download/v0.23.0/alertmanager-0.23.0.linux-amd64.tar.gz
config:
user.user-data: |
#cloud-config
apt:
sources:
grafana:
key: |
packages:
- unzip
- grafana
- make
- git
- python3-pip
runcmd:
devices:
eth0:
type: nic
network: ${LXD_NET}
EOF
# log into the VM
lxc shell o11y
global:
rule_files:
alerting:
alertmanagers:
- static_configs:
- targets:
- localhost:9093
EOF
--enable-feature=remote-write-receiver
Configure Loki
auth_enabled: false
server:
common:
storage:
filesystem:
ring:
kvstore:
store: inmemory
schema_config:
configs:
schema: v11
index:
prefix: index_
period: 24h
ruler:
poll_interval: 1m
storage:
type: local
local:
enable_api: true
EOF
make groups
Start AlertManager
Start Grafana
Export telemetry
# Set this to the address of the VM running Loki and Prometheus
export O11y_IP=<VM_IP>
export GRAFANA_AGENT_PKG=https://github.com/grafana/agent/releases/download/v0.22.0/agent-linux-amd64.zip
chmod a+x /opt/agent/agent-linux-amd64
Copy the agent example configuration from MAAS and start the agent. Adapt the environment variable values to your setup. For example, if you’re using a snap, the MAAS_LOGS variable would be as shown (/var/snap/maas/common/log):
cp /snap/maas/current/usr/share/maas/grafana_agent/agent.yaml.example /opt/agent/agent.yml
-E MAAS_LOGS="/var/snap/maas/common/log/" \
/opt/agent/agent-linux-amd64 \
-config.file=/opt/agent/agent.yml
On the other hand, if you’re using packages, the MAAS_LOGS would be /var/log/maas, as shown below:
-E MAAS_LOGS="/var/log/maas" \
Be sure to adjust the values of the other environment variables to suit your situation, where applicable.
Verify operation
Basic O11y (3.1–)
MAAS services can provide Prometheus endpoints for collecting performance metrics.
Prometheus for MAAS
MAAS can provide five endpoints of particular interest to MAAS users:
- TFTP server file transfer latency
- HTTP requests latency
- Websocket requests latency
- RPC calls (between MAAS services) latency
- Per request DB queries counts
All available metrics are prefixed with maas_, to make it easier to look them up in Prometheus and Grafana UIs.
Whenever you install the python3-prometheus-client library, Prometheus endpoints are exposed over HTTP by the rackd and regiond processes under the default /metrics path.
Pro tip: Currently, prometheus metrics are shared when rack and region controllers are running on the same machine, even though each service provides its own port. You can safely only query one of the two ports if you’re running both controllers.
For a Snap-based MAAS setup, you’re in luck: the necessary libraries are bundled right in, making metrics immediately available. For those on a Debian-based MAAS installation, you’ll need to install the library and give your MAAS services a quick restart. Here’s how:
sudo apt install python3-prometheus-client
sudo systemctl restart maas-rackd
sudo systemctl restart maas-regiond
MAAS also provides optional stats about resources registered with the MAAS server itself. These include four broad categories of information:
- The number of nodes by type, arch, …
- Number of networks, spaces, fabrics, VLANs and subnets
- Total counts for machines CPU cores, memory and storage
- Counters for VM host resources
After installing the python3-prometheus-client library as describe above, run the following to enable stats:
maas $PROFILE maas set-config name=prometheus_enabled value=true
Once the /metrics endpoint is available in MAAS services, Prometheus can be configured to scrape metric values from these. You can configure this by adding a stanza like the following to the prometheus configuration:
- job_name: maas
static_configs:
- targets:
- <maas-host1-IP>:5239 # for regiond
- <maas-host1-IP>:5249 # for rackd
- <maas-host2-IP>:5239 # regiond-only
- <maas-host3-IP>:5249 # rackd-only
If the MAAS installation includes multiple nodes, the targets entries must be adjusted accordingly, to match services deployed on each node.
If you have enabled MAAS stats, you must add an additional Prometheus job to the config:
- job_name: maas
metrics_path: /MAAS/metrics
static_configs:
- targets:
- <maas-host-IP>:5240
In case of a multi-host deploy, adding a single IP for any of the MAAS hosts running regiond will suffice.
Deploy Prometheus
Grafana and Prometheus can be easily deployed using Juju.
The MAAS performance repo repository provides a sample deploy-stack script that will deploy and configure the stack on LXD containers.
First, you must install juju via:
sudo snap install --classic juju
Then you can run the script from the repo:
grafana/deploy-stack <MAAS-IP>
To follow the progress of the deployment, run the following:
watch -c juju status --color
Once you deploy everything, the Grafana UI is accessible on port 3000 with the credentials admin/grafana. The Prometheus UI will be available on port 9090.
The repository also provides some sample dashboard covering the most common use cases for graphs. These are available under grafana/dashboards. You can import them from the Grafana UI or API.
Last updated 1 year, 6 months ago.
