How to install MAAS
Errors or typos? Topics missing? Hard to read? Let us know!
This page explains how to install MAAS from scratch. If you’re already running MAAS, it’s probably easier to upgrade.
Install from Snap
Note that support for PostgreSQL version 12 is deprecated for MAAS version 3.4, and will be discontinued in MAAS 3.5. We recommend upgrading to PostgreSQL version 14 before installing MAAS 3.4.
To install MAAS 3.4 from a snap:
  1. Check the MAAS installation requirements to make sure that your hardware will support MAAS.
  2. Enter the following command:
    sudo snap install --channel=3.4 maas
  3. Enter your account password.
At this point, the snap will download and install from the 3.4 channel.
Note that support for PostgreSQL version 12 is deprecated for MAAS version 3.3, and will be discontinued in MAAS 3.5. We recommend upgrading to PostgreSQL version 14 before installing MAAS 3.3.
To install MAAS 3.3 from a snap:
    sudo snap install --channel=3.3 maas
At this point, the snap will download and install from the 3.3 channel.
To install MAAS 3.2 from a snap:
    sudo snap install --channel=3.2 maas
At this point, the snap will download and install from the 3.2 channel.
To install MAAS 3.1 from a snap:
  2. Install the 3.2 snap:
    sudo snap install --channel=3.1 maas
The snap will download and install from the 3.1 channel.
To install MAAS 3.0 from a snap:
    sudo snap install --channel=3.0 maas
  3. Enter your user password.
The snap will download and install from the 3.0 channel.
To install MAAS 2.9 from a snap:
    sudo snap install --channel=2.9 maas
The snap will download and install from the 2.9 stable channel.
Install from packages
To install MAAS 3.4 from packages:
  2. Add the MAAS 3.4 PPA to your apt repository paths:
    sudo apt-add-repository ppa:maas/3.4
  3. Update your apt repository lists:
    sudo apt update
  4. Install MAAS with the following command:
    sudo apt-get -y install maas
  5. Choose “Y” if asked about whether to continue with the install.
To install MAAS 3.3 from packages:
  2. Add the MAAS 3.3 PPA to your apt repository paths:
    sudo apt-add-repository ppa:maas/3.3
    sudo apt update
To install MAAS 3.2 Deb:
  2. Add the MAAS 3.2 PPA to your apt repository paths:
    sudo apt-add-repository ppa:maas/3.2
    sudo apt update
To install MAAS 3.1 Deb:
  2. Add the MAAS 3.1 PPA to your apt repository paths:
    sudo apt-add-repository ppa:maas/3.1
    sudo apt update
To install MAAS 3.0 Deb:
  2. Add the MAAS 3.0 PPA to your apt repository paths:
    sudo apt-add-repository ppa:maas/3.0
    sudo apt update
To install MAAS 2.9 Deb:
  2. Add the MAAS 2.9 PPA to your apt repository paths:
    sudo apt-add-repository ppa:maas/2.9
    sudo apt update
Some notes
When installing MAAS on Ubuntu, there can be conflicts between the existing NTP client, systemd-timesyncd, and the NTP client/server provided by MAAS, chrony. This can lead to time synchronization issues, especially if MAAS is configured with different upstream NTP servers than the ones used by systemd-timesyncd. To avoid conflicts, users can manually disable and stop systemd-timesyncd using the following command:
sudo systemctl disable --now systemd-timesyncd
Also note that support for PostgreSQL 12 has been deprecated in MAAS 3.3 and will be discontinued in MAAS 3.5.
Test rig
This rig is defined for the MAAS Snap version.
To initialise the MAAS snap in a test/POC configuration, simply use the --help flag with maas init and follow the instructions.
Production MAAS
To install MAAS in a production configuration:
  1. Install PostgreSQL on any machine where you want to keep the database with the following commands:
    sudo apt update -y
  2. Create desired values for the following variables (replace them in the commands below):
    $MAAS_DBUSER = ___________
    $MAAS_DBPASS = ___________
    $MAAS_DBNAME = ___________
    $HOSTNAME = _________
Note that for most situations, you can use localhost for $HOSTNAME.
  1. Create a suitable PostgreSQL user:
    sudo -i -u postgres psql -c "CREATE USER \"$MAAS_DBUSER\" WITH ENCRYPTED PASSWORD '$MAAS_DBPASS'"
  2. Create the MAAS database:
    sudo -i -u postgres createdb -O "$MAAS_DBUSER" "$MAAS_DBNAME"
  3. Edit /etc/postgresql/14/main/pg_hba.conf and add a line for the newly created database:
  4. Initialise MAAS via the following command:
Distributed environment
This environment is defined using MAAS packages.
To run MAAS region and rack controllers on separate machines:
  2. Add the MAAS 3.3 PPA to your apt repository paths on both region and rack target hosts:
  3. Update your apt repository lists on both region and rack hosts:
    sudo apt update
  4. Install the MAAS region controller on the target region host:
  5. Install the MAAS rack controller on the target rack host:
  6. Register the rack controller with the region controller by running the following command on the rack host:
    sudo maas-rack register
These two steps will lead you through two similar apt install sequences.
Create an admin
To create a MAAS administrative user:
  1. Create a MAAS administrator user to access the web UI:
    Substitute $PROFILE is the administrative MAAS username you wish to create. $EMAIL_ADDRESS is an email address you may type in at random (currently, MAAS does not use this email address). The createadmin option will cause MAAS to ask for an SSH key.
  2. To use an SSH key associated with your launchpad accounts, enter lp:$USERNAME (substitute your LP username for $USERNAME).
  3. Alternatively, to use an SSH key associated with your github account, enter gh:$USERNAME (substitute your github username for $USERNAME)
Check MAAS status
To check the status of running services, enter:
sudo maas status
Typical output looks like this:
Your mileage may vary.
More init options
sudo maas init --help
Configure MAAS
To configure MAAS for first-time use:
  1. Access MAAS at this address, where $API_HOST is the hostname or IP address of the region API server, which was set during installation:
    http://${API_HOST}:5240/MAAS
  2. Log in at the prompts, with the login information you created when initialising MAAS.
  3. On the first welcome screen, set the DNS forwarder to a suitable value, e.g., 8.8.8.8. This could be your own internal DNS server, if you have one.
  4. Select an Ubuntu image to import; you may be required to select at least one LTS version.
  5. Click Continue; a screen labelled, “SSH keys for admin:” appears.
  6. In the Source drop-down, select “Launchpad,” “Github,” or “Upload.”
  7. If you want to upload your SSH public key from Launchpad, you would enter the following, where <username> is your Launchpad username:
    lp:<username>
  8. If you want to upload your github public SSH key, you would enter the following, where <username> is your GitHub username:
    gh:<username>
  9. If you want to use your existing public key from your home directory, select Upload.
  10. Copy your entire public key from .ssh/id_rsa.pub (or wherever you may have stored the key).
  11. Paste the public key into the block labelled “Public key.”
  12. Press the “Import” button to import this key.
  13. You should see a message that MAAS has been successfully set up. Click Go to the Dashboard to proceed.
  14. Select Subnets from the top menu.
  15. Choose the VLAN on which you want to enable DHCP.
  16. Select Enable DHCP.
You should now be able to add, commission, and deploy machines.
Once you’ve successfully installed MAAS (regardless of method), you can login to the MAAS CLI via the following process:
  1. Generate the API-key for the login you’re going to use, replacing $PROFILE with whatever username you set during the createadmin part of the install process.
  2. Login with the following command, substituting $MAAS_URL with the URL that was returned to you when you initialised MAAS, for example, 192.168.43.251:5240/MAAS. :
  3. Set upstream DNS (8.8.8.8 is always a reliable value):
  4. Add a public SSH key to a MAAS user account:
  5. See what images you may have already downloaded:
  6. Select an image(s) for download (e.g., “trusty” in this example):
    maas $PROFILE boot-source-selections create 1 os="ubuntu" release="trusty" arches="amd64" subarches="*"  labels="*"
  7. Import your selected image(s):
  8. Identify a valid fabric ID for DHCP (returns "fabric_id": $FABRIC_ID,):
  9. Find the name of the primary rack controller:
  10. Create an IP range for DHCP (in this case, a dynamic range):
  11. Use this collected information to turn on DHCP:
    maas $PROFILE vlan update $FABRIC_ID untagged dhcp_on=True primary_rack=$RACK_CONTR_HOSTNAME
Last updated 12 days ago.
