If you have a large MAAS network, with multiple region and rack controllers, controller tags can help you classify, search, and organise them.
Discover the ID of your region controller(s) (CLI)
| jq -r '(["name","id"]
| @tsv' | column -t
For example:
| @tsv' | column -t
name id
bill-Lenovo-Yoga-C740-15IML 86xya8
Assign tags to a region controller (CLI)
For example:
"added": 1,
"removed": 0
Remove tags from a region controller (CLI)
For example:
"added": 0,
"removed": 1
List tags for all region controllers (CLI)
For example:
hostname sysid tags
bill-Lenovo-Yoga-C740-15IML 86xya8 virtual lxd-vm-host
View tags for one region controller (CLI)
For example:
| @tsv' | column -t
hostname sysid tags
Discover the ID of your rack controller(s) (CLI)
| @tsv' | column -t
For example:
| @tsv' | column -t
name id
Assign tags to a rack controller (CLI)
For example:
"added": 1,
"removed": 0
Remove tags from a rack controller (CLI)
For example:
"added": 0,
"removed": 1
List tags for all rack controllers (CLI)
For example:
hostname sysid tags
View tags for one rack controller (CLI)
For example:
```nohighlight
| @tsv' | column -t
hostname sysid tags
Create controller tags (UI)
To create and assign a controller tag, select Controllers > controller > Configuration > Controller configuration > Edit > Tags. Enter a new tag and Save changes to assign it to the controller.
Delete controller tags (UI)
To remove (and possibly delete) a controller tag, select Controllers > controller > Configuration > Controller configuration > Edit > Tags. Click the X on the tag name to delete it, then select Save changes.
View controller tags (UI)
To view controller tags, select Controllers > controller > Configuration. View the tags for this controller under the Tags row.
Last updated 3 months ago.
