How to manage machines
Maas offers powerful tools to manage machines, from discovery and commissioning to deployment, configuration, and troubleshooting. This guide covers everything you need, whether working with bare metal servers, virtual machines, or pre-deployed systems.
Discover machines
Before managing machines, you need to discover, identify, and locate them.
Discover active devices
MAAS monitors network traffic to automatically detect connected devices, including machines, switches, bridges, and other network hardware.
UI
Networking > Network discovery
CLI
    maas $PROFILE discoveries read
List machines
Show all registered machines
UI
Machines (View list)
CLI
    maas $PROFILE machines read | jq -r '(["HOSTNAME","SYSID","STATUS"] | join(","))'
Show a specific machine
Every machine has a unique system ID; find them with this command:
UI
  1. Machines > [machine]
  2. Check browser URL: ...machine/<SYSTEM_ID>/summary)
CLI
    maas admin machines read | jq -r '(["HOSTNAME","SYSID"] | (., map(length*"-"))),(.[] | [.hostname, .system_id]) | @tsv' | column -t
Use the system ID to get details for a particular machine.
UI
Machines > [Select machine]
CLI
Search for machines
Use MAAS search syntax to find specific machines.
UI
Hardware > *Machines > [Search bar] and enter a search term; MAAS updates the list dynamically.
Search syntax:
Type Example
Exact pod:=able-cattle
Partial pod:able,cattle
Negation pod:!cattle
CLI
Filter machines by parameters
Filter your search against many attributes, using the MAAS UI.
UI
Hardware > Machines > Filters
MAAS dynamically builds search terms that you can mimic, copy and re-use.
Enable new machines
Machines are automatically commissioned when added to MAAS.
Add a machine
To manually add a machine, provide architecture, MAC address, and power settings.
UI
Machines > Add hardware
CLI
    maas $PROFILE machines create architecture=$ARCH \
    mac_addresses=$MAC_ADDRESS power_type=$POWER_TYPE \
    power_parameters_power_id=$POWER_ID \
    power_parameters_power_address=$POWER_ADDRESS
    power_parameters_power_pass=$POWER_PASSWORD
MAAS automatically commissions newly-added machines. To change this, enter:
    maas $PROFILE maas set-config name=enlist_commissioning value=false
Add machines via chassis
Use the chassis feature to add multiple machines at once.
UI
Machines > Add hardware > Chassis > (fill in the form) > Save
Clone a machine
Quickly duplicate an existing machine’s configuration.
UI
Machines > [machine] > Take action > Clone
CLI
    maas $PROFILE machine clone $SOURCE_SYSTEM_ID new_hostname=$NEW_HOSTNAME
Use LXD VMs
MAAS can also provision virtual machines (VMs). LXD is the recommended VM host.
Set up LXD for use with MAAS
Remove old LXD versions
    sudo apt-get autoremove -y
Install & initialize LXD
    sudo snap install lxd
    sudo snap refresh
    sudo lxd init
  • Clustering: no
  • Storage: dir
  • MAAS Connection: no
  • Existing Bridge: yes (br0)
  • Trust Password: Provide a password
Disable DHCP for the LXD bridge
Add a VM HOST
Use the recommended LXD host to create new LXD VMs.
UI
  1. KVM > LXD > Add LXD host > Enter Name, LXD address and select Generate new certificate
  2. Run the provided command in the terminal to add trust.
  3. Check authentication > Add new project | Select existing project > Save LXD host.
CLI
    maas $PROFILE vm-hosts create type=lxd power_address=$LXD_ADDRESS project=$PROJECT_NAME
Add VMs
Newly-created LXD VMs are automatically commissioned by default.
UI
KVM > VM host name > Add VM > Name > Cores > RAM > Disks > Compose machine
CLI
    maas $PROFILE vm-host compose $VM_HOST_ID cores=4 memory=8G disks=1:size=20G
Move VMs between LXD projects
LXD VMs can be moved between LXD projects.
    lxc move $VM_NAME $VM_NAME --project default --target-project $PROJECT_NAME
Delete VMs
Deleted VMs cannot be recovered.
UI
Machine > [machine] > Delete > Delete machine
CLI
Control machine power
Turn machines on if needed; turn them off abruptly or gracefully.
Turn on a machine
Machine booting varies by PXE or deployed OS.
UI
Machines > [machine] > Take action > Power on
CLI
maas $PROFILE machine start $SYSTEM_ID
Turn off a machine
Use this method when you want to immediately turn off a machine.
UI
Machines > [machine] > Take action > Power off
CLI
maas $PROFILE machine stop $SYSTEM_ID
Soft power-off
Use this method to initiate a system shutdown.
maas $PROFILE machine stop $SYSTEM_ID force=false
Set power type
Set the correct power type so MAAS can control the machine.
UI
Machines > [machine] > Configuration > Power > Edit
CLI
    maas $PROFILE machine update $SYSTEM_ID power_type="$POWER_TYPE"
Verifying Redfish activation
You can check if a machine communicates via Redfish with the command:
    dmidecode -t 42
You can also review the 30-maas-01-bmc-config commissioning script’s output if the machine is already enlisted in MAAS.
Commission & test machines
Commissioning gathers hardware information needed to correctly deploy images.
Commission machines
Commission a machine to make it deployable.
UI
Machines > [machine(s)] > Take action > Commission
CLI
Test machines
Ensure the hardware is working correctly.
UI
Machines > [machine(s)] > Take action > Test
CLI
maas $PROFILE machine test $SYSTEM_ID tests=cpu,storage
View test results
Periodically review test results, even when there are no failures.
UI
Machines > [machine(s)] > Test results
CLI
maas $PROFILE machine read $SYSTEM_ID | jq '.test_results'
Override failed tests
UI
Machines > [machine(s)] > Take action > Override test results
CLI
maas $PROFILE machine set-test-result $SYSTEM_ID result=passed
Configure deployment
Set kernel versions, boot options, and storage configuration on deployment; manage hardware sync.
Enable hardware sync (MAAS 3.2+)
To enable hardware sync:
  • MAAS 3.4+ UI:
    Machines > machine > Actions > Deploy > Periodically sync hardware > Start deployment.
  • Other versions UI:
    Take action > Deploy > Periodically sync hardware > Start deployment.
  • CLI:
    maas $PROFILE machine deploy $SYSTEM_ID osystem=$OSYSTEM distro_series=$VERSION enable_hw_sync=true
View hardware sync updates
View updates in the MAAS UI or CLI:
Configure hardware sync interval
Configure the sync interval in MAAS settings.
Configure kernels
Many kernel parameters, including the kernel version, can be specified prior to deployment.
Set kernel version
Set the system-wide, default minimum kernel version for commissioning:
UI
Settings > Configuration > Commissioning > Default minimum kernel version
CLI
Set a default minimum kernel version per machine:
UI
Machines > [machine] > Configuration > Edit > Minimum kernel
CLI
Deploy a machine with a specific kernel:
UI
Machines > [machine] > Take action > Deploy > [Choose kernel]
CLI
Set kernel parameters
Specify system-wide boot options.
UI
Settings > Kernel parameters
CLI
maas $PROFILE maas set-config name=kernel_opts value='$KERNEL_OPTIONS'
Configure storage layout
Specify a default layout for all machines:
UI
Settings > Storage > Default layout
CLI
Specify a storage layout for a specific machine:
UI
Machines > [machine] > Storage > [Edit layout]
CLI
maas $PROFILE machine set-storage-layout $SYSTEM_ID storage_layout=$LAYOUT_TYPE
Machines must be in the “Ready” state to modify their storage layout.
Flat layout
A flat layout means one partition uses the whole disk, formatted with an ext4 filesystem and mounted as root (/). Create a per-machine flat layout with these commands:
UI
Machines > Choose machine > Storage > Change storage layout > Choose dropdown “Flat”
CLI
maas $PROFILE machine set-storage-layout $SYSTEM_ID storage_layout=flat
The flat layout is ideal for general-purpose filesystems that support large files and volumes. A flat layout supports a short list of options, including boot size, root size, and root device designation.
About the flat layout | Flat layout setup reference
LVM layout
An LVM layout offers flexible and dynamic disk management, with easier resizing, snapshots, and volume management. Create an LVM layout with the following commands:
UI
Machines > Choose machine > Storage > Change storage layout > Choose dropdown “LVM”
CLI
maas $PROFILE machine set-storage-layout $SYSTEM_ID storage_layout=lvm
LVM comes in handy when using multiple physical disks as a single, larger volume – something that a flat layout will not support. In addition to the flat configuration options, LVM also supports naming volume groups, as well as creating logical volumes with specific names and sizes.
About the LVM layout | LVM layout setup reference
bcache layout
The bcache layout uses the boot disk as the backing device and a Solid-State Drive (SSD) as the cache. This arrangement speeds up read and write operations by caching frequently-access data on the SSD.
Create a bcache layout with the following commands:
UI
Machines > Choose machine > Storage > Change storage layout > Choose dropdown “bcache”
CLI
maas $PROFILE machine set-storage-layout $SYSTEM_ID storage_layout=bcache
Note that an SSD device must be available to create this layout. If SSD is not available when these commands are given, MAAS defaults to the flat layout.
The bcache layout is useful and cost effective when you want to improve I/O performance by leveraging SSDs as cache for larger, slower disks. Also, applications that are read-intensive can benefit from bcache as well.
bcache introduces new options: the physical block device to use for caching, and the size of cache partition (or “no partition” to use the whole block device).
About the bcache layout | bcache layout setup reference
VMFS6/VMFS7 layouts
The VMFS6 layout is specifically design for deploying VMWare ESXi hosts. It automates the creation of the partitions and datastores required for VMWare. Use the following commands to create a vmfs6 or vmfs7 layout:
UI
Machines > Choose machine > Storage > Change storage layout > Choose dropdown “VMFS6” or dropdown “VMFS7”
CLI
maas $PROFILE machine set-storage-layout $SYSTEM_ID storage_layout=vmfs6
or
maas $PROFILE machine set-storage-layout $SYSTEM_ID storage_layout=vmfs7
The choice of VMFS6 or VMFS7 depends on the VMWare version being deployed. Both layouts allow you to specify the root device and root filesystem size. Note that the resultant filesystem layout should not be altered.
VMFS6/7 layout setup reference
Blank layout
The blank layout removes all existing storage configuration from a machine’s disks. No actual disk layout is provided, so partitions, filesystems and mount points must be created manually. Create this layout with the following commands:
UI
Machines > Choose machine > Storage > Change storage layout > Choose dropdown “No storage…”
CLI
maas $PROFILE machine set-storage-layout $SYSTEM_ID storage_layout=blank
Note that machines with the blank layout cannot be deployed; you must first configure storage manually or via curtin in a commissioning script.
Custom layouts
MAAS version 3.1 and higher allow you to define a custom storage layout for a machine, via a custom commissioning script. You must upload a script which conforms to the following rules:
  • it must run after the 40-maas-01-machine-resources script and before the 50-maas-01-commissioning one, so it should have a name that starts with anything between 41- and 49-. This ensures the script can access the JSON file created by the former which provides info about the machine hardware and network resources. In addition, the custom script can directly inspect the machine it’s running on to determine how to configure storage.
  • it can read machine hardware/network information from the JSON file at the path specified by $MAAS_RESOURCES_FILE
  • it must output a JSON file at the path specified by $MAAS_STORAGE_CONFIG_FILE with the desired storage layout
  • names of disks provided in the custom layout must match the ones detected by MAAS and provided in the resources file.
Config format
The configuration contains two main sections:
  • layout, which lists the desired storage layout in terms of disks and volumes, along with their setup (partitions, volumes, …).
    This consists of a dictionary of device names and their configuration. Each device must have a type property (see below for supported types).
  • mounts, which lists the desired filesystem mount points.
    As an example:
"mounts": {
    "device": "sda2",
    "options": "noatime"
  "/boot/efi": {
    "device": "sda1"
  "/data": {
    "device": "raid0"
A complete $MAAS_STORAGE_CONFIG_FILE would look like this:
    "layouts": {
        "sda": {
        "raid0": {
    "mounts": {
The following device types are supported in the "layout" section:
Disk
"sda": {
  "type": "disk",
  "ptable": "gpt",
  "boot": true,
  "partitions": [
      "name": "sda1",
      "fs": "vfat",
      "size": "100M"
      "bootable": true,
A disk entry defines a physical disk.
The following details can be specified:
  • the partition table type (ptable), which can be gpt or mbr
  • whether it should be selected as boot disk
  • optionally, a list of partitions to create, with their size and filesystem type (fs)
LVM
"lvm0": {
  "type": "lvm",
  "members": [
    "sda1",
    "sdb1",
  "volumes": [
      "name": "data1",
      "size": "5G",
      "fs": "ext4"
      "name": "data2",
      "size": "7G",
      "fs": "btrfs"
An lvm entry defines a VG (volume group) composed by a set of disks or partitions (listed as members). Optionally it’s possible to specify the the LVs (logical volumes) to create.
Those are defined similarly to partitions, with a name and size (and optionally the filesystem).
Bcache
"bcache0": {
  "type": "bcache",
  "cache-device": "sda",
  "backing-device": "sdf3",
  "cache-mode": "writeback",
  "fs": "ext4"
A bcache entry must specify a device to use as cache and one to use as storage. Both can be either a partition or a disk.
Optionally the cache-mode for the Bcache can be specified.
RAID
"myraid": {
  "type": "raid",
  "level": 5,
  "members": [
    "sda",
    "sdb",
    "sdc",
  "spares": [
    "sdd",
    "sde"
  "fs": "btrfs"
A raid entry defines a RAID with a set of member devices.
Spare devices can also be specified.
Deploy machines
Deploy machines to make them available for use.
Allocate a machine
Claim exclusive ownership of a machine to avoid conflicts.
UI
Machines > [machine(s)] > Take action > Allocate
CLI
Deploy a machine
Simultaneously deploy multiple machines, if desired, within resource limits.
UI
Machines > [machine(s)] > Take action > Deploy > Deploy machine
CLI
Deploy to RAM (ephemeral deployment)
Deploy an ephemeral instance (into machine RAM, ignoring any disk drives).
Learn more about ephemeral deployment
UI
Machines > [machine(s)] > Take action > Deploy > Deploy in memory > Deploy machine
CLI
maas $PROFILE machine deploy $SYSTEM_ID ephemeral_deploy=true
Deploy as a VM host
Deploy a bare-metal machine as a virtual machine host.
UI
Machines > [machine] > Take action > Deploy > Install KVM
CLI
Deploy with custom cloud-init scripts
Use cloud-init to vary machine use-cases and application loads.
UI
Machines > [machine] > Take action > Deploy > Configuration options
CLI
maas $PROFILE machine deploy $SYSTEM_ID cloud_init_userdata="$(cat cloud-init.yaml)"
Rescue & recovery
Use rescue mode to log onto a running machine and diagnose issues.
Enter rescue mode
UI
Machines > [machine] > Take action > Enter rescue mode
CLI
maas $PROFILE machine enter-rescue-mode $SYSTEM_ID
SSH into a machine to diagnose issues
Diagnose machine failures using standard tools and methods.
    ssh ubuntu@$MACHINE_IP
Exit rescue mode
Attempt to put the machine back in service.
UI
Machines > [machine] > Take action > Exit rescue mode
CLI
maas $PROFILE machine exit-rescue-mode $SYSTEM_ID
Mark a machine as broken
Indicate to all users that a machine is not currently usable.
UI
Machines > [machine] > Take action > Mark broken
CLI
maas $PROFILE machines mark-broken $SYSTEM_ID
Mark a machine as fixed
Remove the “broken” designation.
UI
Machines > [machine] > Take action > Mark fixed
CLI
maas $PROFILE machines mark-fixed $SYSTEM_ID
Release or remove machines
Release a machine to return it to the “Ready” state. Remove a machine to permanently delete it from MAAS.
Release a machine
MAAS will indicate if a machine cannot currently be released.
UI
Machines > [machine] > Take action > Release
CLI
maas $PROFILE machines release $SYSTEM_ID
Erase disks on release
Erasing a disk can take a long time, depending on the chosen method.
UI
Machines > [machine] > Take action > Release > Enable disk erasure options
CLI
maas $PROFILE machine release $SYSTEM_ID erase=true secure_erase=true quick_erase=true
Delete a machine
Once deleted, a machine cannot be recovered.
UI
Machines > [machine] > Take action > Delete
CLI
Force delete a stuck machine
Force MAAS to delete a stuck machine using the CLI only.
maas $PROFILE machine delete $SYSTEM_ID force=true
Verify everything
Periodically review your machine list to verify settings.
UI
Machines > (View list or search)
CLI
maas $PROFILE machines read | jq -r '.[].hostname'
Last updated 8 days ago.
