How to use machine tags
How to create and assign machine tags to machines
If you want to create a new tag, and simultaneously assign it to one or more machines, use the following steps:
  1. Select Machines.
  2. Select the checkbox next to the machine(s) you want to tag.
  3. Select Categorise >> Tag.
  4. Create and/or assign the desired tag, as described in the general tagging procedure above.
  5. Select Save to register your changes.
How to remove and delete machine tags from machines
  1. Select Machines.
  2. Select the machine in question by clicking on its name.
  3. Check the Tags pane under Machine summary to confirm the tags applied to the machine.
  4. Select Edit.
  5. Follow the general tag removal procedure.
How to list machine tags for multiple machines
In the MAAS UI, you don’t explicitly list all machine tags; instead, you filter by them using the “Filters” drop-down:
  1. Select Machines.
  2. Select the Filters dropdown.
  3. Select Tags in the dropdown.
  4. Select one or more tags by clicking on the tag name.
The machine list will automatically filter by (be limited to) the machines matching the selected tag(s).
Remove a tag from the search filter by either by deselecting it in the Tags section.
How to view machine tags for one machine
  1. Select Machines.
  2. Select the machine of interest by clicking on its name.
  3. Select Configuration.
  4. Scroll down to the Tags section.
How to view machine tags for a VM host
  1. Under KVM, select the type of VM host you’re investigating.
  2. Select a VM host by clicking on its name.
  3. Select KVM host settings.
  4. You can view, edit, add, or delete tags in the Tags box.
  1. Select Machines.
  3. Select Take action >> Tag.
  5. Select Tag machine to register your changes.
  1. Select Machines.
  4. Select Configuration >> Edit.
  • To list all tags, visit the ‘Machines’ tab and expand the ‘Tags’ subsection in the left pane. In this view, you can use tags as machine search filters.
  • Select one or several tags. The machines that satisfy all selected tags will display on the right pane. Notice there is a search field at the top of the right pane. You can type a search expression into this field.
  • On the machine list, select the machine of interest by clicking on its name.
  • On the machine detail screen that comes up, look for the tags on one of the cards presented there: the tags for that machine should be listed there.
  1. Select KVM.
How to assign machine tags to a machine
For example:
   "added": 1,
   "removed": 0
| @tsv' | column -t
hostname       sysid   machine_tags
divine-stork   8b3ypp  pod-console-logging  virtual
casual-prawn   4end6r  pod-console-logging  virtual
driven-teal    tgaat6  pod-console-logging  virtual
immune-beetle  43xand  pod-console-logging  virtual
good-osprey    napfxk  pod-console-logging  virtual
smart-hen      c4rwq7  pod-console-logging  virtual
boss-satyr     xn8taa  pod-console-logging  androko
golden-martin  8fxery  pod-console-logging  virtual
crack-guinea   qk4b3g  pod-console-logging  virtual
finer-leech    cy3dtr  pod-console-logging  virtual
free-mouse     gxtbq4  pod-console-logging  virtual
humble-bunny   srqnnb  pod-console-logging  virtual
wanted-muskox  ekw7fh  pod-console-logging  virtual
one-boa        by477d  pod-console-logging  virtual
great-urchin   srnx4g  pod-console-logging  virtual
ace-frog       g6arwg  pod-console-logging  virtual  barbar  farquar  new_tag
alive-marlin   gbwnfb  pod-console-logging  virtual
picked-parrot  am77wn  pod-console-logging  virtual
tough-kit      ke3wc7  pod-console-logging  virtual
legal-whale    8nq3mt  pod-console-logging  virtual
game-sponge    76pdc6  pod-console-logging  virtual
fun-ghoul      qxfm7k  pod-console-logging  virtual
aware-earwig   8m8hs7  pod-console-logging  virtual
chief-crane    7fapx7  pod-console-logging  virtual
select-tapir   4ascbr  pod-console-logging  virtual
on-slug        snfs8d  pod-console-logging  virtual
polite-llama   dbqd4m  pod-console-logging  virtual
frank-coyote   wcmk48  pod-console-logging  virtual
usable-condor  ed8hmy  pod-console-logging  virtual
still-imp      h6ra6d  pod-console-logging  virtual
How to remove machine tags from a machine
For example:
    "added": 0,
    "removed": 1
Adding and removing machine tags simultaneously from multiple machines
    "added": 2,
    "removed": 1
| @tsv' | column -t
golden-martin  8fxery  pod-console-logging  virtual  barbar
one-boa        by477d  pod-console-logging  virtual  barbar
ace-frog       g6arwg  pod-console-logging  virtual  farquar
How to list machine tags for all machines
For example:
| @tsv' | column -t
For example:
| @tsv' | column -t
How to discover your virtual machine host ID
maas $PROFILE vmhosts read \
| @tsv' | column -t
For example:
maas admin vmhosts read \
| @tsv' | column -t
vm_host_name      id
my-lxd-vm-host-1  1
How to assign tags to a virtual machine host
maas $PROFILE vmhost add-tag $VMHOST_ID	tag=$TAG_NAME
If it worked, this should return Success, followed by the JSON that describes the VM host. You can check your work by listing all VM host tags.
How to remove tags from a virtual machine host
How to list tags for all virtual machine hosts
For example:
vm_host_name      id  tags
my-lxd-vm-host-1  1   morkopongo  pod-console-logging  virtual
How to view tags for one virtual machine host
| @tsv' | column -t
name              id  tags
Last updated a month ago.
