How to manage machines
MAAS offers powerful tools to manage machines, from discovery and commissioning to deployment, configuration, and troubleshooting. This guide covers everything you need, whether working with bare metal servers, virtual machines, or pre-deployed systems.
Discover and find machines
Before managing machines, you need to discover, identify, and locate them.
Discover active devices
MAAS monitors network traffic to automatically detect connected devices, including machines, switches, bridges, and other network hardware.
UI
Networking > Network discovery
CLI
    maas $PROFILE discoveries read
Find a machine’s system ID
Everything in MAAS revolves around the system ID, which is easily located.
UI
  1. Machines > [machine]
  2. Check browser URL: ...machine/<SYSTEM_ID>/summary)
CLI
    maas admin machines read | jq -r '(["HOSTNAME","SYSID"] | (., map(length*"-"))),(.[] | [.hostname, .system_id]) | @tsv' | column -t
List machines
View all the machines in your MAAS instance.
UI
Machines (View list)
CLI
    maas $PROFILE machines read | jq -r '(["HOSTNAME","SYSID","STATUS"] | join(","))'
Related: Commission machines | Control power
Search for machines
Use MAAS search syntax to find specific machines.
UI
Hardware > *Machines > [Search bar] and enter a search term; MAAS updates the list dynamically.
Search syntax:
Type Example
Exact pod:=able-cattle
Partial pod:able,cattle
Negation pod:!cattle
CLI
Filter machines by parameters
Filter your search against many attributes, using the MAAS UI.
UI
Hardware > Machines > Filters
MAAS dynamically builds search terms that you can mimic, copy and re-use.
Add & configure machines
By default, machines are automatically commissioned when added to MAAS.
Add a machine
To manually add a machine, provide architecture, MAC address, and power settings.
UI
Machines > Add hardware
CLI
    maas $PROFILE machines create architecture=$ARCH \
    mac_addresses=$MAC_ADDRESS power_type=$POWER_TYPE \
    power_parameters_power_id=$POWER_ID \
    power_parameters_power_address=$POWER_ADDRESS
    power_parameters_power_pass=$POWER_PASSWORD
MAAS automatically commissions newly-added machines. To change this, enter:
    maas $PROFILE maas set-config name=enlist_commissioning value=false
Add machines via chassis
Use the chassis feature to add multiple machines at once.
UI
Machines > Add hardware > Chassis > (fill in the form) > Save
Clone a machine
Quickly duplicate an existing machine’s configuration.
UI
Machines > [machine] > Take action > Clone*
CLI
    maas $PROFILE machine clone $SOURCE_SYSTEM_ID new_hostname=$NEW_HOSTNAME
Set power type
Set the correct power type so MAAS can control the machine.
UI
Machines > [machine] > Configuration > Power > Edit
CLI
    maas $PROFILE machine update $SYSTEM_ID power_type="$POWER_TYPE"
Verifying Redfish activation
You can check if a machine communicates via Redfish with the command:
    dmidecode -t 42
You can also review the 30-maas-01-bmc-config commissioning script’s output if the machine is already enlisted in MAAS.
Add LXD for VM hosts
LXD setup is straightforward.
Remove old LXD versions
    sudo apt-get autoremove -y
Install & initialize LXD
    sudo snap install lxd
    sudo snap refresh
    sudo lxd init
  • Clustering: no
  • Storage: dir
  • MAAS Connection: no
  • Existing Bridge: yes (br0)
  • Trust Password: Provide a password
Disable DHCP for LXD’s bridge
Add a VM HOST
Use the recommended LXD host to create new LXD VMs.
UI
  1. KVM > LXD > Add LXD host > Enter Name, LXD address and select Generate new certificate
  2. Run the provided command in the terminal to add trust.
  3. Check authentication > Add new project | Select existing project > Save LXD host.
CLI
    maas $PROFILE vm-hosts create type=lxd power_address=$LXD_ADDRESS project=$PROJECT_NAME
Add VMs
Newly-created LXD VMs are automatically commissioned by default.
UI
KVM > VM host name > Add VM > Name > Cores > RAM > Disks > Compose machine
CLI
    maas $PROFILE vm-host compose $VM_HOST_ID cores=4 memory=8G disks=1:size=20G
Move VMs between projects
LXD VMs can be moved between LXD projects.
    lxc move $VM_NAME $VM_NAME --project default --target-project $PROJECT_NAME
Delete VMs
Deleted VMs cannot be recovered.
UI
Machine > [machine] > Delete > Delete machine
CLI
Control machine power
Turn machines on if needed; turn them off abruptly or gracefully.
Turn on a machines
Machine booting varies by PXE or deployed OS.
UI
Machines > [machine] > Take action > Power on
CLI
maas $PROFILE machine start $SYSTEM_ID
Turn off a machine
Use this method when you want to immediately turn off a machine.
UI
Machines > [machine] > Take action > Power off
CLI
maas $PROFILE machine stop $SYSTEM_ID
Soft power-off
Use this method to initiate a system shutdown.
maas $PROFILE machine stop $SYSTEM_ID force=false
Commission & test machines
Commissioning gathers hardware information needed to correctly deploy images.
Commission a machine
Commission a machine to make it deployable.
UI
Machines > [machine(s)] > Take action > Commission
CLI
Run tests
Ensure the hardware is working correctly.
UI
Machines > [machine(s)] > Take action > Test
CLI
maas $PROFILE machine test $SYSTEM_ID tests=cpu,storage
View test results
Periodically review test results, even when there are no failures.
UI
Machines > [machine(s)] > Test results
CLI
maas $PROFILE machine read $SYSTEM_ID | jq '.test_results'
Override failed tests
UI
Machines > [machine(s)] > Take action > Override test results
CLI
maas $PROFILE machine set-test-result $SYSTEM_ID result=passed
Deploy machines
Deploy machines to make them available for use.
Allocate a machine
Claim exclusive ownership of a machine to avoid conflicts.
UI
Machines > [machine(s)] > Take action > Allocate
CLI
Deploy a machine
Simultaneously deploy multiple machines, if desired, within resource limits.
UI
Machines > [machine(s)] > Take action > Deploy > Deploy machine
CLI
Deploy to RAM
Deploy an ephemeral instance (into machine RAM, ignoring any disk drives).
Learn more about ephemeral deployment
UI
Machines > [machine(s)] > Take action > Deploy > Deploy in memory > Deploy machine
CLI
maas $PROFILE machine deploy $SYSTEM_ID ephemeral_deploy=true
Deploy as a VM host
Deploy a bare-metal machine as a virtual machine host.
UI
Machines > [machine] > Take action > Deploy > Install KVM
CLI
Deploy with custom cloud-init scripts
Use cloud-init to vary machine use-cases and application loads.
UI
Machines > [machine] > Take action > Deploy > Configuration options
CLI
maas $PROFILE machine deploy $SYSTEM_ID cloud_init_userdata="$(cat cloud-init.yaml)"
Configure other deployment settings
Set kernel versions, boot options, and storage configuration on deployment; manage hardware sync.
Enable hardware sync (MAAS 3.2+)
To enable hardware sync:
  • MAAS 3.4+ UI:
    Machines > machine > Actions > Deploy > Periodically sync hardware > Start deployment.
  • Other versions UI:
    Take action > Deploy > Periodically sync hardware > Start deployment.
  • CLI:
    maas $PROFILE machine deploy $SYSTEM_ID osystem=$OSYSTEM distro_series=$VERSION enable_hw_sync=true
View Hardware Sync Updates
View updates in the MAAS UI or CLI:
Configure Hardware Sync Interval
Configure the sync interval in MAAS settings.
Set kernel version
Set the system-wide, default minimum kernel version for commissioning:
UI
Settings > Configuration > Commissioning > Default minimum kernel version
CLI
Set a default minimum kernel version per machine:
UI
Machines > [machine] > Configuration > Edit > Minimum kernel
CLI
Deploy a machine with a specific kernel:
UI
Machines > [machine] > Take action > Deploy > [Choose kernel]
CLI
Set kernel parameters
Specify system-wide boot options.
UI
Settings > Kernel parameters
CLI
maas $PROFILE maas set-config name=kernel_opts value='$KERNEL_OPTIONS'
Configure storage layout
Specify a default layout for all machines:
UI
Settings > Storage > Default layout
CLI
Specify a storage layout for a specific machine:
UI
Machines > [machine] > Storage > [Edit layout]
CLI
maas $PROFILE machine set-storage-layout $SYSTEM_ID storage_layout=$LAYOUT_TYPE
Rescue & recovery
Use rescue mode to log onto a running machine and diagnose issues.
Enter rescue mode
UI
Machines > [machine] > Take action > Enter rescue mode
CLI
maas $PROFILE machine enter-rescue-mode $SYSTEM_ID
SSH into a machine to diagnose issues
Diagnose machine failures using standard tools and methods.
    ssh ubuntu@$MACHINE_IP
Exit rescue mode
Attempt to put the machine back in service.
UI
Machines > [machine] > Take action > Exit rescue mode
CLI
maas $PROFILE machine exit-rescue-mode $SYSTEM_ID
Mark a machine as broken
Indicate to all users that a machine is not currently usable.
UI
Machines > [machine] > Take action > Mark broken
CLI
maas $PROFILE machines mark-broken $SYSTEM_ID
Mark a machine as fixed
Remove the “broken” designation.
UI
Machines > [machine] > Take action > Mark fixed
CLI
maas $PROFILE machines mark-fixed $SYSTEM_ID
Release or remove machines
Release a machine to return it to the “Ready” state. Remove a machine to permanently delete it from MAAS.
Release a machine
MAAS will indicate if a machine cannot currently be released.
UI
Machines > [machine] > Take action > Release
CLI
maas $PROFILE machines release $SYSTEM_ID
Erase disks on release
Erasing a disk can take a long time, depending on the chosen method.
UI
Machines > [machine] > Take action > Release > Enable disk erasure options
CLI
maas $PROFILE machine release $SYSTEM_ID erase=true secure_erase=true quick_erase=true
Delete a machine
Once deleted, a machine cannot be recovered.
UI
Machines > [machine] > Take action > Delete
CLI
Force delete a stuck machine
Force MAAS to delete a stuck machine using the CLI only.
maas $PROFILE machine delete $SYSTEM_ID force=true
Verify everything
Periodically review your machine list to verify settings.
UI
Machines > (View list or search)
CLI
maas $PROFILE machines read | jq -r '.[].hostname'
Last updated 9 hours ago.
