How to put machines to work
The ultimate purpose of MAAS is to deploy and manage machines. It’s important to understand how images get deployed – as explained in About the machine life-cycle, machines must first be enlisted or commissioned, then allocated, then deployed. This article will help you build on that understanding by explaining:
How to commission a machine
Note that if you are using your own commissioning scripts, and you do not want them to automatically run every time, you must specify noauto, as in this script snippet:
#!/bin/bash
# name: 50-script-example
# title: Example
# description: Just an example
# script_type: commissioning
# tags: noauto
If you do not specify noauto, your custom commissioning scripts will run every time commissioning is attempted.
To commission a machine:
  • Go to the “Machines” page.
  • Select the machine(s) you want to commission.
  • Choose “Commission” under the “Take action” drop-down menu:
These options include:
  • Allow SSH access and prevent machine powering off: Machines are normally powered off after commissioning. This option keeps the machine on and enables SSH so you can access the machine.
  • Retain network configuration: When enabled, preserves any custom network settings previously configured for the machine. See Networking for more information.
  • Retain storage configuration: When enabled, preserves any storage settings previously configured for the machine. See Storage for more details.
  • Update firmware: Runs scripts tagged with update_firmware.
  • Configure HBA: Runs scripts tagged with configure_hba.
  • Click the Hardware tests field to reveal a drop-down list of tests to add and run during commissioning. See Hardware testing for more information on hardware testing scripts.
  • Finalise the directive by hitting “Commission machine”.
To commission a machine that’s in the “Ready” state, via the CLI, use the following command:
Typical JSON output (long listing)
    "storage_test_status_name": "Pending",
    "bcaches": [],
    "cpu_count": 1,
    "interface_set": [
            "params": "",
            "numa_node": 0,
            "tags": [],
            "id": 10,
            "mac_address": "52:54:00:15:36:f2",
            "vendor": "Red Hat, Inc.",
            "children": [],
            "effective_mtu": 1500,
            "discovered": [],
            "links": [],
            "link_speed": 0,
            "link_connected": true,
            "system_id": "bhxws3",
            "enabled": true,
            "interface_speed": 0,
            "firmware_version": null,
            "name": "ens3",
            "sriov_max_vf": 0,
            "product": null,
            "vlan": {
                "vid": 0,
                "mtu": 1500,
                "dhcp_on": true,
                "external_dhcp": null,
                "relay_vlan": null,
                "fabric": "fabric-2",
                "primary_rack": "8dwnne",
                "name": "untagged",
                "id": 5003,
                "space": "undefined",
                "secondary_rack": null,
                "fabric_id": 2,
            "parents": [],
            "type": "physical",
            "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/"
    "numanode_set": [
            "index": 0,
            "memory": 985,
            "cores": [
                0
    "locked": false,
    "hardware_uuid": "F677A842-571C-4E65-ADC9-11E2CF92D363",
    "default_gateways": {
        "ipv4": {
            "gateway_ip": null,
            "link_id": null
        "ipv6": {
            "gateway_ip": null,
            "link_id": null
    "status_action": "",
    "status_message": "Commissioning",
    "memory_test_status": -1,
    "virtualblockdevice_set": [],
    "pool": {
        "name": "default",
        "id": 0,
    "current_testing_result_id": 9,
    "netboot": true,
    "description": "",
    "special_filesystems": [],
    "testing_status": 0,
    "memory": 1024,
    "current_commissioning_result_id": 8,
    "storage": 5368.70912,
    "commissioning_status": 0,
    "cpu_test_status": -1,
    "tag_names": [
        "virtual"
    "swap_size": null,
    "status_name": "Commissioning",
    "other_test_status": -1,
    "pod": null,
    "storage_test_status": 0,
    "blockdevice_set": [
            "id_path": "/dev/disk/by-id/ata-QEMU_HARDDISK_QM00001",
            "size": 5368709120,
            "block_size": 512,
            "tags": [
                "ssd"
            "serial": "QM00001",
            "uuid": null,
            "numa_node": 0,
            "available_size": 5368709120,
            "id": 3,
            "partition_table_type": null,
            "model": "QEMU HARDDISK",
            "storage_pool": null,
            "used_for": "Unused",
            "filesystem": null,
            "used_size": 0,
            "partitions": [],
            "name": "sda",
            "type": "physical",
            "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/blockdevices/3/"
    "distro_series": "",
    "testing_status_name": "Pending",
    "ip_addresses": [],
    "address_ttl": null,
    "physicalblockdevice_set": [
            "firmware_version": "2.5+",
            "uuid": null,
            "numa_node": 0,
            "size": 5368709120,
            "tags": [
                "ssd"
            "id": 3,
            "filesystem": null,
            "used_size": 0,
            "partitions": [],
            "name": "sda",
            "block_size": 512,
            "type": "physical",
    "fqdn": "ace-swan.maas",
    "osystem": "",
    "domain": {
        "authoritative": true,
        "ttl": null,
        "resource_record_count": 0,
        "name": "maas",
        "id": 0,
        "is_default": true,
    "boot_interface": {
        "params": "",
        "numa_node": 0,
        "tags": [],
        "id": 10,
        "children": [],
        "discovered": [],
        "links": [],
        "link_speed": 0,
        "enabled": true,
        "name": "ens3",
        "sriov_max_vf": 0,
        "product": null,
        "vlan": {
            "vid": 0,
            "mtu": 1500,
            "dhcp_on": true,
            "relay_vlan": null,
            "name": "untagged",
            "id": 5003,
            "fabric_id": 2,
        "parents": [],
        "type": "physical",
    "hostname": "ace-swan",
    "network_test_status": -1,
    "min_hwe_kernel": "",
    "power_state": "off",
    "owner_data": {},
    "volume_groups": [],
    "power_type": "virsh",
    "node_type": 0,
    "owner": "admin",
    "cache_sets": [],
    "hwe_kernel": null,
    "zone": {
        "name": "default",
        "description": "",
        "id": 1,
    "disable_ipv4": false,
    "boot_disk": {
        "uuid": null,
        "numa_node": 0,
        "size": 5368709120,
        "tags": [
            "ssd"
        "id": 3,
        "filesystem": null,
        "used_size": 0,
        "partitions": [],
        "name": "sda",
        "block_size": 512,
        "type": "physical",
    "status": 1,
    "iscsiblockdevice_set": [],
    "raids": [],
    "node_type_name": "Machine",
    "hardware_info": {
        "system_vendor": "QEMU",
        "system_product": "Standard PC (i440FX + PIIX, 1996)",
        "system_family": "Unknown",
        "system_version": "pc-i440fx-focal",
        "system_sku": "Unknown",
        "system_serial": "Unknown",
        "cpu_model": "Intel Core Processor (Skylake, IBRS)",
        "mainboard_vendor": "Unknown",
        "mainboard_product": "Unknown",
        "mainboard_firmware_vendor": "SeaBIOS",
        "mainboard_firmware_date": "04/01/2014",
        "mainboard_firmware_version": "1.13.0-1ubuntu1",
        "chassis_vendor": "QEMU",
        "chassis_type": "Other",
        "chassis_serial": "Unknown",
        "chassis_version": "pc-i440fx-focal"
    "commissioning_status_name": "Pending",
    "bios_boot_method": "pxe",
    "interface_test_status": -1,
    "cpu_speed": 0,
    "resource_uri": "/MAAS/api/2.0/machines/bhxws3/"
If you need to find the machine’s $SYSTEM_ID, you can use a command like this one:
"ace-swan"
"bhxws3"
Once commissioned, you may consider adding a tag to this machine. The next step is testing and deployment.
How to test machines
This section explains:
How to upload scripts
How to debug script failures
How to upload hardware testing scripts
How to list all uploaded hardware testing scripts
How to update hardware testing scripts
"history": [
        "id": 40,
        "comment": "Updated version"
        "id": 34,
        "comment": null
How to revert hardware testing scripts
MAAS keeps a history of all uploaded script versions, allowing you to easily revert to a previous version, using the id of the desired version:
The history for later modifications will be lost when reverting to an earlier version of the script.
How to download a script
How to delete a script
How to view script results
How to filter script results
How to suppress failed results
"results": [
        "id": 21,
        "name": "smartctl-validate",
        "status": 5,
        "status_name": "Aborted",
        "exit_status": null,
        "runtime": "0:00:00",
        "endtime": 1554238601.765214,
        "parameters": {
            "storage": {
                "argument_format": "{path}",
                "type": "storage",
                "value": {
                    "id_path": "/dev/vda",
                    "model": "",
                    "name": "sda",
                    "physical_blockdevice_id": 1,
                    "serial": ""
        "script_id": 1,
        "script_revision_id": null,
        "suppressed": true
How to locate script files
  • /tmp/user_data.sh.*/scripts/commissioning/: Commissioning scripts
  • /tmp/user_data.sh.*/scripts/testing/: Hardware testing scripts
How to locate log files
  • /tmp/user_data.sh*/out/
  • /var/log/cloud-init-output.log
  • /var/log/cloud-init.log
    [--no-download] \
    [--no-send] \
    /tmp/user_data.sh.*
Where:
  • --no-download: Optional. Do not download the scripts from MAAS again.
  • --no-send: Optional. Do not send the results to MAAS.
How to apply a hardware test
A default test will be selected (smartctl-validate, a hard drive test) but you can choose others by clicking the ‘Select scripts’ label. Doing so will reveal the following choices:
See Commissioning scripts reference for more details on how these scripts work and how you can write your own.
How to upload hardware test scripts
"history": [
        "id": 40,
        "id": 34,
        "comment": null
How to use tags to group commissioning and testing scripts
How to view testing results
"results": [
        "id": 21,
        "status": 5,
        "parameters": {
            "storage": {
                "type": "storage",
                "value": {
                    "model": "",
                    "name": "sda",
                    "serial": ""
        "script_id": 1,
        "suppressed": true
MAAS can check whether links are connected or disconnected, so that you can detect unplugged cables. If you are not running MAAS 2.7 or higher, you must first upgrade and then recommission your machines to find disconnected links. MAAS not only reports unplugged cables, but also gives a warning when trying to configure a disconnected interface. In addition, administrators can change the cable connection status after manually resolving the issue.
| @tsv' | column -t
| @tsv' | column -t
Administrators can change or update the link and interface speeds after manual changes to the connection:
This functionality is only available through the MAAS CLI.
Via the Web UI only, MAAS can check this link and recognise that there’s no connectivity, which alleviates hard-to-detect network issues:
  • Interfaces which have a broken network configuration
  • Bonds that are not fully operational
  • Broken gateways, rack controllers, and Internet links
To test individual interfaces, for example, you could issue the following CLI command:
How to allocate machines
To allocate a node with the web UI, select a machine which is in the “Ready” state, and drop down the “Take action” menu:
Select “Allocate” from the drop-down menu, which will bring you to a confirmation screen:
MAAS will allocate the selected machine; you can now find it in the list of “Allocated” machines:
To allocate a random node:
To allocate a specific node:
To allocate a node, it must have a status of ‘Ready’.
How to deploy machines
To deploy directly from MAAS, select one or more machine(s) and press the ‘Deploy’ button.
You then have the option of deviating from the default OS, release, and kernel. When ready, press ‘Deploy X machine(s)’ (where ‘X’ is the number of machines selected).
While a machine is deploying its status will change to Deploying to ‘OS’, where ‘OS’ is the name of the OS being deployed (e.g. ‘Deploying to Ubuntu 16.04 LTS’).
Once a machine has finished deploying its status will change to just the name of the OS (e.g. ‘Ubuntu 18.04 LTS’).
To deploy a node:
To deploy with the CLI, the node must have a status of ‘Allocated’. See ‘Allocate a node’ above.
Configure deployment timeout
By default, when you deploy a machine, MAAS will consider the deployment a failure if it doesn’t complete within 30 minutes. You can configure this timeout, if you wish, with the command:
How to enlist a machine that’s already running a workload
In order to add machine that’s already running a workload, there are currently two options:
Via the API/CLI, you can create a machine, passing the deployed flag:
$ maas $profile machines create deployed=true hostname=mymachine \
architecture=amd64 mac_addresses=00:16:3e:df:35:bb power_type=manual
On the machine itself (the recommended way, if the machine is running Ubuntu), you can download a helper script from MAAS and create the machine that way:
$ wget http://$MAAS_IP:5240/MAAS/maas-run-scripts
$ chmod 755 maas-run-scripts
$ ./maas-run-scripts register-machine --hostname mymachine \
 > http://$MAAS_IP:5240/MAAS $MAAS_API_TOKEN
Now you have a machine in MAAS that’s in the deployed state, with no hardware information yet.
How to update hardware information for a deployed machine
The recommended way of updating the hardware information for a deployed machine is to download the maas-run-scripts script and run it on the machine itself:
$ ./maas-run-scripts report-results --config mymachine-creds.yaml
If you created the machine with the maas-run-scripts, you should have such a mymachine-creds.yaml file already. If not, it should look like this:
reporting:
          maas:
            consumer_key: $CONSUMER_KEY
            endpoint: http://$MAAS_IP:5240/MAAS/metadata/status/$SYSTEM_ID
            token_key: $TOKEN_KEY
            token_secret: $TOKEN_SECRET
You may get the needed credentials from the MAAS API, for example:
$ maas $profile machine get-token wxwwga
        "token_key": "Lyy9BS4tKsQakDQScy",
        "token_secret": "V8vta8Azwn6FZVkfHnuTvLGLScAvEufB",
        "consumer_key": "YGT6QKSH65aap4tGnw"
Last updated a month ago.
