You can manipulate machine block storage devices with the MAAS CLI. Note that block devices cannot be managed through the MAAS UI.
List block devices
Output:
"id": 10,
"serial": ",
"block_size": 4096,
"available_size": 0,
"filesystem": null,
"id_path": "/dev/vda",
"size": 5368709120,
"model": ",
"type": "physical",
"uuid": null,
"used_size": 5365563392,
"partitions": [
"bootable": false,
"id": 9,
"size": 5360320512,
"type": "partition",
"filesystem": {
"mount_options": null,
"label": null,
"fstype": "lvm-pv",
"mount_point": null
"tags": [
"rotary"
"name": "vda"
"id": 11,
"serial": null,
"block_size": 4096,
"filesystem": {
"label": "root",
"fstype": "ext4",
"mount_point": "/"
"id_path": null,
"size": 3221225472,
"partition_table_type": null,
"model": null,
"type": "virtual",
"used_size": 3221225472,
"partitions": [],
"tags": [],
"name": "vgroot-lvroot"
Read block device
"name": "vgroot-lvroot",
"type": "virtual",
"filesystem": {
"mount_point": "/",
"fstype": "ext4",
"label": "root"
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
MAAS allows the name of a block device to be changed. If the block device name has changed then the API call needs to use the new name. Using the ID is safer as it never changes.
Create block device
"name": "vdb",
"used_for": "Unused",
"type": "physical",
"used_size": 0,
"filesystem": null,
"id_path": ",
"id": 12,
"block_size": 4096,
"tags": [],
"uuid": null,
"serial": "QM00001",
"partitions": [],
"size": 21474836480,
"model": "QEMU"
Update block device
"block_size": 4096,
"filesystem": null,
"model": "QEMU",
"name": "newroot",
"partitions": [],
"tags": [],
"used_size": 0,
"id_path": ",
"uuid": null,
"id": 12,
"type": "physical",
"serial": "QM00001"
Delete block device
Format block device
"block_size": 4096,
"size": 3221225472,
"filesystem": {
"label": ",
"fstype": "ext4",
"mount_point": null
"model": null,
"partitions": [],
"tags": [],
"id_path": null,
"id": 11,
"type": "virtual",
"serial": null
Unformat block device
"available_size": 3221225472,
"type": "virtual",
"used_size": 0,
"filesystem": null,
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
Mount block device
"type": "virtual",
"filesystem": {
"mount_point": "/srv",
"mount_options": ",
"fstype": "ext4",
"label": "
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
Unmount block device
"type": "virtual",
"filesystem": {
"mount_point": null,
"fstype": "ext4",
"label": "
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
Boot from block device
Only an administrator can set which block device should be used as the boot disk and only a physical block device can be set as as the boot disk. This operation should be done before a machine is allocated or the storage layout will be applied to the previous boot disk.
Last updated 1 year, 2 months ago.
